underlayment
Last Post 21 Sep 2010 09:10 PM by greentree. 8 Replies.
StonelakeUser is Offline
19 Sep 2010 05:51 PM
We are planning on using a standing seam metal roof on our 4-12 pitch sips roof. We are considering using a self adhesive   (ice & water barrier) for underlayment, over felt paper.  The reason being less threat of being blown off,  less penetrations in osb, and ease of installation. might justify the cost increase.   Any thoughts or recommendations?
19 Sep 2010 06:53 PM
Stonelake;
thats the wrong installation the IWB is meant to take the place of felt , it is meant to stick to the deck, sticking it to felt is a waste of money and the product
19 Sep 2010 09:58 PM
IWB over felt would also be a real mess and a nightmare to install!
20 Sep 2010 05:30 PM
sorry.............what I was saying  was to use the IWB in place of felt.........................
greentreeUser is Offline
20 Sep 2010 07:26 PM
Ice and water and ease of installation doesnt go together, unless it's cold enough so it doesn't bond. Use a synthetic underlayment with cap nails, it's light, easy to roll on, lays flat and doesn't wrinkle or tear. The cap nails will seal your staple penetrations.
20 Sep 2010 11:26 PM
My carpenter indicated that the IWB goes on easy, and will stay put despite wind.  He says he has seen it stay on a long time if the roofing installation is delayed for months with no bad effects.   What is the name of the product that you are referring to?
21 Sep 2010 07:16 AM
Posted By Stonelake on 20 Sep 2010 11:26 PM
there are many on the market, some for shingles , some hi-temp for metal, why don't you ask you carpenter which one he like to use?
21 Sep 2010 08:33 AM
My peel and stick underlayment has been on for months exposed to the weather, and not one bit of it has moved, curled, or anything. The only problem so far is the "walkable" surface, which is like a thin white felt mat, is starting to degrade and is not so walkable anymore on the steep parts.
I guess it would go on easy on a 4/12. Steeper pitches and hot weather and it's a pain to roll out fast, flat with no bubbles and overlapped properly efficiently. Really cold and it won't bond well and wont roll out flat unless always stored upright.  Stuff is a pain. Most cases you need to snap lines.
Synthetic underlay resembles housewrap and comes in 10 sq rolls (4'x250') Preprinted fastening locations and easy to walk on. There are many manufacturers and I've tried several, I like PermaFelt and Rex and hate Typar's. Thing is, it's less than $12 a square versus $60+ a square for IWB.
People Online People Online: Visitors Visitors: 321 Members Members: 0 Total Total: 321
