Structural Insulated Panels (SIPs)
installing panels
Last Post 29 Sep 2010 08:57 PM by
Stonelake
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Stonelake
28 Sep 2010 05:23 PM
I have been noticing the different ways in which installers handle panels. Some have plates with a pick eye which would require several screws into one layer of the osb, and I have seen others that drill a whole all the way through the panel and insert a strap to handle the panels, and fill the whole later with foam. Which is best? Or is there even a better way to handle the panels?
cmkavala
29 Sep 2010 06:47 AM
the drilled thru eye bolt with a back up plate it the safest, screws can rip out of OSB
Chris Kavala<br>
[email protected]
<br>1-877-321-SIPS<br />
wes
29 Sep 2010 07:46 PM
We have used a large eye bolt donated to us by a local utility crew for several years. It works very well and the holes filled with foam have created no problems.
I understand that there is a new clamping device designed to work specifically for lifting SIPS. However, I can drill and fill a lot of holes for the $2000+ pricetag, and what happens if the clamp doesn't set properly? Think I will stick with my eye bolt for the time being.
Wes Shelby<br>Design Systems Group<br>Murray KY<br>
[email protected]
Stonelake
OK Thanks for the good information.....
Membership:
croccohvacusa
People Online:
