I have a question about repairing a roof panel. A roof leak over many years caused a large area of rot (around 4x4') in a roof SIP under a skylight. The replacement OSB was not glued down but I realize this should have been done so I would like to get this repaired and done correctly.
I have two questions...
Regarding the glue, I have read several threads on this topic but there isn't a concise answer. Would something like Enerbond work just as well as an adhesive that coats the entire EPS surface? I believe Enerbond and PL300 would be applied in rows so not 100% of the foam would be covered.
Also, obviously the replacement OSB would be nailed to our 2x8 engineered lumber splines. However, would it also make sense to use H-clips or mending plates at the top and bottom of the replaced OSB? Seems something like H-clips would give the OSB added strength.
Thanks for your help and happy holidays.
