Tubular Steel roof trusses are used for large span constructions such
as factories, industry worksheds, shopping malls, huge exhibition
centres, multiplexes etc. They are generally used for spans as large as
25-30m.
There is a similar kind of a truss called “Tubular Steel Monitor Roof
Truss“. There are projections on the roofs called “Monitors” to admit
daylight into the space.
- It is in two halves with bolted joints at P and Q, the remaining joints being 5mm fillet welds made in the workshop.
- The main tie member rises 130mm from L to N to counteract any appearance of sag that would be evident if it were horizontal.
Read the rest of this entry »
U can read more here http://www.civilengineergroup.com/structural-engineering/steel-structure
