Post and beam with OSB SIPs problem
Last Post 09 Feb 2011 03:37 PM by BEK. 2 Replies.
BEKUser is Offline
09 Feb 2011 09:04 AM
Working on a 18 year old Post and Beam house with SIPs, OSB interior/exterior sheetrock finish.
Marvin Wood windows, Tyvek building paper and roughsawn cedar shiplap vertical siding.
Windows were never flashed, no drip cap flashing, openings were not wrapped,Tyvek paper was installed after windows so there is a 1/2" gap of building paper.
The windows are rotting out at sills and frames and there is damage to the OSB in areas around some windows.
There are also some sections at the foundation (which was not  built to prescribed kit size) where the siding is flush allowing water at shiplap joint to hit slab and wick up OSB.
The house has manufacturer's recommended ventilation system, humidity level seems OK needs to be checked, there is no damage on interior. All window damge can be attributed to poor installation, lack of flashing and possibly a Marvin FJ wood issue.
Windows and doors need to be replaced and OSB repaired in spots. Budget is an issue, thought about removing and replacing one window at a time, repairing OSB, packing out area around window(void left from casing) to flush up with existing siding. Wrap opening and flash properly, then apply Tyvek over Cedar siding and applying finish horizontal clapboard over. Would there be any condensation issues with two layers of building paper. The cedar siding would act as a better nail base and correct the problem with the foundation. Any tips on repairing OSB and other feedback would be appreciated.
09 Feb 2011 10:22 AM
do you have any photos to analyze the extent of the damage? If the damage is minor I might just treat the OSB (liquid copper) to prevent further rot and cover perimiter of opening with metal flashing
BEKUser is Offline
I do not have any photos at this time. On the one window I rebuilt, there was minor rot on the OSB., so I applied Vycor and then lead coated copper flashing at head and sill.
People Online People Online: Visitors Visitors: 316 Members Members: 0 Total Total: 316
