If you're truely Environmentally Conscious, what you want is Pre-Insulated, Recycled Content Steel Framing Structural Panels. Bonded Expaned Polystyrene and Recycled Content Galvanized Steel. 100% Recyclable, R-VALUES from R-17 To R-40 in conjunction with gypsum wallboard. Obtainable
Class A-Class 1 Fire Ratings, Metro Dade Hurricane Rated, Superior Accoustical Properties and they are not going to Wick and Absorb Water like an OSB Spunge. 100 New Growth Trees can be replaced with 2 Recycled Automobiles. Energy Star Partner Rated. Reducing Utility Costs for heating and cooling by 50% or More! Ship Lap Joints for zero air transmission. The Four in One Panel, Sheathing, Framing, Insulation and Vapor Barrier. Vertical and Horizontal Load Bearing to 4 Stories High. Capable of supporting Interior and Exterior Cladding and Drywall. So if you're a Professional Contractor in the Commercial Construction Field, you can drop the Rep a Line at
[email protected]
