7,000 Sq. Ft. SIP house
Last Post 26 Nov 2017 08:28 PM by cmkavala. 97 Replies.
Page 5 of 5 << < 12345
Author Messages Informative
07 Feb 2013 10:20 AM
Is that a tile roof on the home? Does the metal SIP roof have to be reinforced to hold the weight of a Spanish Tile/Concrete Tile roof?
What kind of exterior finish are they planning on?
07 Feb 2013 04:44 PM
Posted By Lbear on 07 Feb 2013 10:20 AM
Peter,
stone coated metal tile, but I have used concrete tiles on the roofs before, Take a closer look, the walls are white stucco, trims are not yet painted
07 Feb 2013 06:45 PM
Posted By cmkavala on 07 Feb 2013 04:44 PM
Peter,
The white gets sort of washed in the photo detail and it's hard to tell if it was the SIP or a stucco finish. Is that an EIFS stucco?
How thick are those SIPs?
07 Feb 2013 06:56 PM
Posted By Lbear on 07 Feb 2013 06:45 PM
Peter,
6" walls and 6" roof
paperbacked wire lath and 3/4" cement stucco
07 Feb 2013 07:01 PM
Posted By ICFHybrid on 07 Feb 2013 09:15 AM
My concern is two fold. Firstly, I don't think that fan has the oomph to do the job in that great room. Secondly, it just LOOKS too small in there. Folks on my build will tell you there is nothing I hate more than a change order, once something is done, but I'd do it for that fan. The BigAss fan continues to be one of the major WOW factors on my build. I'll try to remember to get an image today.
ICF,
The fan is actually 6 ft wide which is enormous for a residential fan,
I think the problem is the ceiling treatment is a lot larger
ICFHybridUser is Offline
08 Feb 2013 01:18 AM
This is a BigAss Fan in an atrium about 16 feet across.  The fan blades are located at just under 30 feet off the ground and it is a 10 foot diameter fan.  It is taped in plastic to guard against dust and paint overspray.
08 Feb 2013 04:13 PM
They make great fans. They recommend running them at low speed during winter in rooms with high ceilings to circulate the air and keep the warm air from pooling at the top.
08 Feb 2013 10:22 PM
With residential steel SIP construction, is the EPS foam treated with borates and fire retardants?
Do the steel SIPs come with a fire rating?
09 Feb 2013 06:38 AM
Posted By Lbear on 08 Feb 2013 10:22 PM
Lbear,
I cannot generalize for all steel SIP manufacturers,
as far as I know:
all use fire redardant foam
not all use borates and some charge extra for it
none have a fire rating, but steel is non combustible.
most comply with the UL 1715 (UBC 26-3 )Fire Test
The panels quoted to your job have retardants and borates and comply with UL 1715
09 Feb 2013 07:03 AM
Lbear,
The panels quoted to you have the following tests and certifications:
ASTM E1996-02
ASTM E1886-02
SBCCI / SSTD 12-99
ASTM E1592-01
ASTM E108-04 Fire Testing
UL 1715 (UBC 26-3) Fire Testing
ASTM E90
AC 05 ICC-ES Panel Adhesive Test
ASTM E 72-02 Racking & Shear Wall Load With and Without Corner Condition
ASTM C 1363-05 Thermal Performance
ASTM E119 - 05a Unsymetrical Load-Bearing Wall Fire Tests of Building Construction & Materials
Transverse Load Testing ICC-ES AC04 Includes Simulated Door and Window Openings
Axial Load Testing ICC-ES AC04
Concentrated Load Testing ICC-ES AC04
Bond Strength Testing ICC-ES AC04
Core Shear Modulus ICC-ES AC 04
Fastener Withdrawal Tests ICC-ES AC04
Connection Load Test ICC-ES AC04
09 Feb 2013 05:33 PM
Thanks for the info! So with the ASTM E108-04 Fire Rating it is a Class B roof, correct? That is the bare SIP without another roofing protection layer on top?
Do the borates, fire retardants and tests apply for the 2LB foam also?
10 Feb 2013 06:59 PM
What do you guys do in the HVHZ areas? The 2010 Florida Building Code really went crazy and made areas like Dade County a 180MPH wind zone. I can only see concrete/masonry structures being able to withstand those types of winds.
10 Feb 2013 07:43 PM
Posted By Lbear on 10 Feb 2013 06:59 PM
Lbear,
Once you go ver 140 mph a rediron frame clad with panels is needed, I don't like doing business in Dade County ,
but a freind of mine recently did a 180 mph in the keys
rnortmanUser is Offline
10 Feb 2013 08:36 PM
Posted By cmkavala on 10 Feb 2013 07:43 PM
Lbear,
Is there a particular benefit to cladding with SIPs when something else (steel frame, concrete, and/or masonry) is providing the weight-bearing structure?  Is it cost effective compared to more traditional ways of insulating those structures?
10 Feb 2013 09:23 PM
Posted By rnortman on 10 Feb 2013 08:36 PM
Lbear,
Yes,
a least 50% more energy efficient,
there is nothing conventional @ 180mph
12 Aug 2017 11:31 PM
Had the occasion to to get by this house today was finished 4 years ago , but I don't often get by to get Final pictures like this since it is a gated community
the round tower walls and roof are all SIPs
26 Nov 2017 07:27 PM
Very Impressive! Chris
Posted By JeffD on 26 Nov 2017 07:27 PM
Thanks!
Membership Membership: Latest New User Latest: HotnCold New Today New Today: 0 New Yesterday New Yesterday: 0 User Count Overall: 34723
People Online People Online: Visitors Visitors: 123 Members Members: 0 Total Total: 123
