foundation with groove design
Last Post 05 Oct 2012 09:31 AM by JeffD. 2 Replies.
norUser is Offline
04 Oct 2012 03:43 AM
hi, need input on this. here the thing.. i saw mostly SIPs panels using bottom plate to attach the panel to the foundation. but if we prepare the foundation with the groove design, the panels can just be slot it.
The problem lies in first the groove must be always be within the depth and length so that the panels can be slot it. Another one, if it rain, the water might go it (flashing perhaps to prevent water penetration?)? Anything perhaps to improve this system? thanks!
04 Oct 2012 04:29 AM
Posted By nor on 04 Oct 2012 03:43 AM
unless SIPs have been tested for below grade foundations, I think it is a bad Idea
nor,
I will assume you have wood SIPs in mind. Ledges or troughs in the edge of a foundation that could collect moisture should be avoided. Wood SIPs should be kept high and dry. Also the inner and outer skin should be evenly supported to develope full load capability.
People Online People Online: Visitors Visitors: 215 Members Members: 0 Total Total: 215
