Posted By Got2BTru on 10 Jan 2013 05:52 PM
Hey all...came across this site tonight as I am researching using SIPs. My wife & I are leaving Texas (too HOT!) and moving North to my home area of upstate NY (between Syracuse & Utica).
We purchased 32 acres & I've been working with an architect for floor plans. As I talk with builders (I've also seen a few comments online), I keep having the question of long term integrity coming up. OSB, when wet, is not pretty.
It would seem that if the OSB got wet, that would affect the structural integrity of the house and any load being placed on the OSB. Am I missing something?
That's the downside of OSB/wood SIPs. They must be kept dry or at the very least, allowed to dry out if they get wet. The latter is not always accomplished and what eventually happens is called SIP ROT. That is where the wood panel rots and delaminates from the EPS, therefore compromising on the strength and integrity of the entire panel.
With that being said, the one solution is
Steel SIPs. Nothing to rot and delaminate, plus they are stronger, lighter and can span longer distances. Especially for roof applications,
Steel SIPs is the way to go.
When it comes to walls, the same proper detailing must be done to make sure the exterior OSB is kept dry and if it does get wet, allowed to dry out properly.
What wood SIP companies are now doing for roof applications is installing furring strips onto the exterior side of wood roof SIPs. They would then run another layer of OSB over the furred channel area. For the roof area, this then creates a drainage/vent plane so when the OSB gets wet, the furred channel allows drying. Building Science now recommends this detail for OSB roof SIPs. Sadly, there are some SIP companies that are still not using this detail and I don't doubt problems will emerge 10-15 years from now. See below pic:
In extreme cases, especially humid and rainy climates, if you don't let the panels dry out by using a detail like the above, this can happen:
