Posted By haese56 on 01 Jun 2013 10:59 AM
I've heard various advice regarding sheeting over the OSB prior to putting up my siding. Tyvek seems redundant . One young builder I spoke with said if he were doing his own house he would not put anything between the siding and the OSB thus eliminating any possibility to trap moisture. I'm going with vertical cement board siding, 7" reveal. I've also heard conflicting advice on nailing vs screwing seeing as how SIPS has no studs to hit.
The emphasis on "young" and obviously lacking experience, If you do not put a moisure barrier the OSB will certainly get wet and lead to rot, consult your siding manufacturer's attachment recommendation, theirs are instructions not advice
