Possible to retrofit EPS concrete sandwich panel on an old Post and beam home?
Last Post 31 Dec 2013 11:51 AM by [email protected]. 4 Replies.
PailUser is Offline
13 Oct 2013 10:03 AM
I have recently bought an old post and beam home. It is now just basically a frame on a slab. The home came with no insulation at all. I was wondering if it would be possible to fix EPS concrete panels to the exterior frame or even between the posts themselves. Would this be structurally sound? Would it be better to use OSB foam sips? This would provide reasonable insulation. The house is a two story rectangle and about 300 square feet.
FBBPUser is Offline
14 Oct 2013 10:45 AM
jppie - it depends on how the original foundation id designed.
Are the posts carried by their own footings or is everything supported by the slab?
What type of eps concrete panels are you thinking of?
[email protected]User is Offline
27 Dec 2013 04:25 PM
Would the concrete panels be heavy and hard to maneuver into place under the beams?
29 Dec 2013 10:22 AM
You might look into applying EPS to the outside and covering it with mesh and stucco (like a low strength SCIP). The inside could be covered with gypsum and the resulting cavity could be filled with sprayed cellulose.
EZ SIPS Build-In-Place Structural Insulated Panels are R-19 & R-25 Styrofoam(TM) panels you build into standard 16" OC WALLS as you frame. Pre-cut recesses for 2x4 / 2x6 studs & plates + BUILT-IN THERMAL BREAK. Simply slide 4' wide x 8/9/10' EZ SIPS panels down into framing before nailing sheathing for SUPER PRE-INSULATED wall panels CUSTOM FABRICATED on site…in minutes! Superior to factory SIPs at HALF the cost! Open inner walls, convenient horizontal/vertical snap-out electrical/plumbing runs + 23% thicker insulation.
People Online People Online: Visitors Visitors: 214 Members Members: 0 Total Total: 214
