Posted By Banerpan on 23 May 2014 02:19 PM
Thanks, that will help my engineer
Pierre Desjardins
what your engineer should need is not in the "prescriptive " method , each manufacturer's testing will be different.,
therefore, different span / load capabilities, rack & shear values.
those are available to professionals in the industry, but in the wrong hands could be mis interpreted.
if you read the prescriptive method it has limitations on length , width and height of buildings and only useful up to 130 mph wind zones
an engineer is needed and should obtain the test data specific to your manufacturer, data from manufacturer ABC is not applicable to manufacterer XYZ
