3 story SIP home
Last Post 20 Apr 2015 09:14 PM by cmkavala. 19 Replies.
Author Messages Informative
12 Dec 2014 08:45 PM
3 story SIP design with hip roof design, Simonton storm breaker (impact glass) windows Marinoware Joist rite with 3/4" advantec subfloor.............................................
12 Dec 2014 08:58 PM
Posted By cmkavala on 12 Dec 2014 08:45 PM
18 Mar 2015 08:24 PM
Finished.............
gosolarUser is Offline
19 Mar 2015 07:59 AM
Chris, if I recall your panels are metal clad not osb correct?
what are the max size of a panel?
can you convert standard plans to sips and have the windows elec chases precut
Where are they manufactured?
19 Mar 2015 10:43 PM
Posted By gosolar on 19 Mar 2015 07:59 AM
gosolar, yes galvalume steel skins,
maximum thickness is 12" and maximum length is 53'
there is no pre cutting or electrical chases
the panels for that house were done by Permatherm
27 Mar 2015 04:32 PM
updated photos -complete owner moving in tomorrow ................. ..........................
wdkayUser is Offline
15 Apr 2015 06:44 AM
Chris, I am looking at using cfs joist in our house. Do you know what the spans are in the photo you posted? I am trying to clear span 20' and have a deflection of l/480 or l/600. Nice house. Looks like it's right on the ocean dune line.
Thank you
David
15 Apr 2015 02:15 PM
Posted By wdkay on 15 Apr 2015 06:44 AM
Thank you
David,
what load @ L/480?
15 Apr 2015 02:27 PM
David ,
a 12" joist x 12 ga will span 22.1' @ 24" oc with a 15# dead load / 40# live load @ L/480
or a 14" joist x 14 ga. will span 23.0' with same loading/spacing,
Maximum span for a 14"x 12 ga joist @ 12" oc (same load) is 34.7'
15 Apr 2015 11:02 PM
Chris, The plans call for 20# dead load and 60# live load. 2nd floor sleeping areas are 20# dead and 50# live. The plans are drawn for GPI's. The first floor is over a crawl space so it has a drop girder at center span. The second floor would be the clear span. 16" on center for first floor and 12" on center for 2nd floor. Flooring will be white oak over both floor areas.
Thank you
David
16 Apr 2015 05:39 AM
Posted By wdkay on 15 Apr 2015 11:02 PM
Thank you
David
David,
you can accomplish that with a 12" x 16 ga. @ 12" oc or a 12" x 14 ga. @ 16" oc.
16 Apr 2015 02:47 PM
Thank you for the information. It's not like you can go somewhere and they have a floor that you can walk on and it is a l/480. All my other house were in Fl and they were SOG. This will be the first with floor joist.
Again, thank you for taking the time to answer my questions.
David
17 Apr 2015 10:11 AM
Is it possible to run a SIP roof screw through a 3/16" steel beam? I assume the beam would be pre-drilled.
TorbenUser is Offline
17 Apr 2015 12:59 PM
Yes. http://www.trufast.com/products/sip_nail/siphd.html
17 Apr 2015 04:04 PM
Posted By Lbear on 17 Apr 2015 10:11 AM
Trufast HDs are rated at 3/16" steel , but I have gone thru as thick as 1/2"
17 Apr 2015 08:41 PM
Chris, Will the screws penetrate both cold rolled (galvanized) and hot rolled (hard) steel?
17 Apr 2015 09:31 PM
Posted By Alton on 17 Apr 2015 08:41 PM
Hot rolled mild steel, I beams and H beams, as much as 1/2", in one case have seen them drill thru 1/2" and 1/2" splice plate , very good self drill/ self tap screws
18 Apr 2015 07:27 PM
Posted By wdkay on 16 Apr 2015 02:47 PM
David
Pictures taken from a current build with 14" x 14 ga. joists @24" oc.spanning 24' - 0"
receiver track for joist
14" allows room for ducting
20 Apr 2015 02:42 PM
Do you see any labor, time or price difference between the marinoware and the CD trade ready joist? I wonder cause it doesn't seem like the marinoware rim joist have the pre punched tabs.
Seems like it would add time and labor installing those.
Thank you
David
David, lately the Marinoware has been a little less than CD, but I would probably even pay more for them because: 1. they are lighter, 2. they attain greater spans,3. they have greater duct capabilities , marinoware has precut angle clips for attachment, I don't think the prepunched clips are that big of an advantage and have had CD ship us the receiver track with the wrong spacing on clips, the job comes to a halt, until you get the replacement, it won't happen with the marinoware as you can set any spacing that you want
People Online People Online: Visitors Visitors: 222 Members Members: 0 Total Total: 222
