45 or 36 degree corners with metal SIP??
Last Post 03 Jan 2015 09:37 PM by Alton. 7 Replies.
gerutaUser is Offline
03 Jan 2015 06:28 PM
may be building a retirement house in coastal florida. Have a plan I like in OSB sip but can't see using that in FL. Is there any trick to non-90degree corners? Thanks in advance for replies
03 Jan 2015 07:09 PM
Posted By geruta on 03 Jan 2015 06:28 PM
geruta,
you can make any angle you want, by applying break metal to the outside and inside skins
03 Jan 2015 07:23 PM
all of these jobs have angled walls
03 Jan 2015 07:36 PM
Thanks Chris. Not sure what you mean by break metal, but sounds like a site-built adaptation, does this make the panel-to-panel joint weaker than the factory joint? does it create a gap that needs to be foamed? Thanks again.
03 Jan 2015 07:44 PM
geruta,
The factory makes the break metal to match the angle that you want the walls to be, the actual panel cuts are done in the field and then stiched together with the angled metal, an expansion foam is used to close the gap
There are no factories manufacturing "pre-Made" angled corners, it is a field made corner,
03 Jan 2015 07:48 PM
geruta, brake metal is simply sheet metal that has been bent. It is very common and all angles are possible. Any steel SIP project (regardless of angles) will employ brake metal, and the joint will not be any weaker.
03 Jan 2015 08:00 PM
OK got it. so even the standard 90deg corners would get the same treatment. the factory seams are in the straight section between adjacent panels only. The brake metal is then attached to the SIPs with screws I presume... Thanks!
The bent metal is attached with stitch screws (short screws through one skin) at a fairly close interval.
People Online People Online: Visitors Visitors: 323 Members Members: 0 Total Total: 323
