MgO Panels as Exterior or Wet Area Skins
Last Post 11 Aug 2016 09:16 AM by Innova. 4 Replies.
Author Messages Informative
MgOCorpUser is Offline
06 Jan 2015 07:13 PM
MgO Corps wishes to start 2015 clearly & openly expressing to all members looking to build with SIPs using mgo skins the need to be vigilant & not blind or mislead about the quality & standards of everyday mgo products. During 2014 MgO Corp carried out extensive testing which has led to our organization no longer accepting mgo manufacturer or suppliers stated performances of the products they make & distribute. Comprehensive test data proves that over 95% of mgo products are not suitable for the applications they are promoted & sold to the consumer for. WARNING: SGS Accredited testing under taken by MgO Corp under the guidelines of the American ICC-ES Standards for use as an Exterior and Wet Area Lining (ASTM C1185/86) clearly ruled out the use of (ALL) tested Common / Standard mgo products !! That's correct, All High Quality Test Samples failed to pass all the ASTM guidelines notably water permeability. As a resulted MgO Corp has developed a full range of specific engineered "Fit for Purpose" products that have been fully tested & approved under all aspects of ASTM C1185/86, accredited by CodeMark & under ICC for use in all areas of building & construction in America, Australia, New Zealand, Malaysia & Sweden including Exterior & Wet Area Linings. MgO Corp over the past 6yrs has invested heavily into understanding all the characteristics & performances of mgo when utilized in SIP &, Panelized Systems so as to firstly mitigate risk to our company & our clients and secondly to be able to deliver a product that will truly deliver the performances we promote to the best of its ability. MgO Corp found out the hard way also that the vast majority of supporting ISO & Testing Documents supplied by so called manufactures & trading houses are fake or been changed to show a result the buyer has asked for. It take only 5 minutes of your time ring the appropriate 3rd Party accreditation authority as well as the testing laboratory & gain clear confirmation that the products you are buying are indeed genuine & approved for the applications you wish to use it in. The above is meant to open your eyes to be aware of what is really going on in the global mgo world and has been doing so unchecked for to long. Like any product you can get good and bad. Just be careful and be aware "that cheap can turn into expensive" when building. A Fully Accredited and 3rd Party Audited Magnesium Oxide Board Product that has all the Acoustic, Impact, Fire, Water, VOC & Structural Engineering Data will deliver to your next project amazing long term performance well beyond the traditional Gypsum, FC Drywall & you will enjoy a healthier and safer place to live and work for generations to come. MgO Corp can be contacted any time through our website if you require our assistance. www.mgoboard.com.au
20 Jan 2015 07:04 AM
A MgO SIP house just went up near me. I should ask for a sample and do some testing. They claim that the price is the same as other building materials (such as block and SCIP), but I didn't get exact figures.
20 Jan 2015 08:48 AM
jonr I think it's time to post pics of said MgO SIP project!
InnovaUser is Offline
11 Aug 2016 09:05 AM
Energy Efficient MGO SIP Homes. Our low moisture MGO board can be tapped and finished like drywall. Attached images of painted MGO SIP houses. Painted MGO SIP looks like smooth stucco without the cost of the stucco finish. Build the Houses of the Future Today, with InnovaPanels
MGO SIPs at the Miami Seaquarium - The InnovaPanel, a patented MGO SIP panel was used to construct the new Penguin Exhibit in Miami Florida. The energy efficient MGO SIP panels were taped, finished and painted similar to drywall. MGO is moisture resistant and was a perfect choice for the wet environment conditions inside the animal habitat. Attached images show the MGO SIP panels which were painted with exterior paint. The InnovaPanel is a patented MGO SIP Panel manufactured in Miami Florida by Innova Eco Building System. javascript:amaf_insertHTML('');amaf_toggleInline(5654,24560,0); javascript:amaf_insertHTML('');amaf_toggleInline(5655,24560,0);
Attachment: Miami-Sea-MGO-SIP.jpg
Attachment: Miami-Sea-2.jpg
