ICF or poured foundation for SIP walls?
Last Post 25 May 2015 10:46 AM by smartwall. 6 Replies.
ICFfamUser is Offline
21 May 2015 04:56 AM
I am building a new polyurethane SIP shop this summer and am trying to decide between an ICF foundation or a conventional foundation that benefits from 2" of foam applied on the inner edge like what is done at https://www.youtube.com/watch?v=-hb6CvHgoJM. Any assistance would be greatly appreciated!
gosolarUser is Offline
21 May 2015 10:04 PM
I think the video is old school the cost is higher and more labor than IFC.
I'm planning one now doing the foundation with 2 by's and placing the IFC on supports on top of those forms, one pour thru the IFC kinda filling the foundation, wait a bit to let the foundation setup some then fill the IFC
here's a drawing
http://www.foxblocks.com/media/7062/Stem-Foundation-Wall-Typ-Details.pdf
22 May 2015 07:54 AM
Posted By gosolar on 21 May 2015 10:04 PM
here's a drawing
thats not what your detail is showing , the footer would be poured first , then set the ICF on top of the hardened footer
smartwallUser is Offline
22 May 2015 08:50 AM
Actually you can pour the footer, icf wall and slab in one step
22 May 2015 10:54 AM
Or use a frost protected shallow foundation and you don't have any footer at all - just a slab with turned down edges.
22 May 2015 03:06 PM
Posted By smartwall on 22 May 2015 08:50 AM
smartwall, I don't see how that is a possibility, since there would be earth against an unpoured ICF form? can you show the detail on that?
I use a system that I developed, but there is a commercially available version from Branch River Plastics in RI. I think it is called Fast Form. When I came up with the idea for a mono pour system 11 years ago, I thought when that worked why not use it with frost walls with a slab. It's actually not that crazy. You just have to use the right products.
People Online People Online: Visitors Visitors: 190 Members Members: 0 Total Total: 190
