28 Unit SIP constructed employee Housing in Bahamas
Last Post 22 Nov 2016 09:08 PM by cmkavala. 35 Replies.
Author Messages Informative
03 Aug 2015 03:16 PM
Under 90 days start to finish including interior .......
13 Sep 2015 08:33 PM
This quote from the Builder/Developer DuraVilla USA to the owner .............. “The structure: The panel system and design worked out well. All components were delivered and ready for assembly. There were no issues with panel size, fit and finish. All fasteners, channel and track were here and ready for assembly. The design worked out exactly as anticipated and meets the scope of work agreed to. The rooms are very nice and practical just as designed. All windows and doors work out as planned and were easily installed. The balconies and stairs work as planned and met the needs for access and egress.”
Posted By cmkavala on 13 Sep 2015 08:33 PM
LeepInvestorUser is Offline
19 Sep 2015 02:53 PM
Anyone ever hear of LeepCore SIP's? If so, any thoughts about them? Leep's SIP's seem to be second to none.
23 Oct 2015 10:32 PM
Interior photos,
25 May 2016 06:15 PM
These just in from the developer
YunionBoardUser is Offline
26 May 2016 01:51 AM
Thanks a lot for sharing photos of SIPs.
Live Green With Yunion<br />
www.yunionboard.com<br />
manufacturer of <A href="http://www.yunionboard.com/product/mgo-board">mgo panels</A>, <A href="http://www.yunionboard.com/product/chloride-free-mgo-board">chloride free mgo board</A>, <A href="http://www.yunionboard.com/product/fiber-cement-panels">fiber cement panels</A>, and <A href="http://www.yunionboard.com/product/calcium-silicate-board">calcium silicate board</A>
vh2qUser is Offline
26 May 2016 10:52 AM
This must be a government project because the heavy import duty on SIPs in the Bahamas negates all of the economic advantage in that country. Government does not care about duty obviously, from one pocket to the other. A pity because it's a great solution for that climate (need A/C) and the prevalence of termites. The other factor though is you have to make it hurricane proof and that requires a LOT of heavy structural lumber between the panels and complicates assembly (the studs have to be fastened both sides to the bottom plate with L brackets and to get access to both sides of the stud you have to cut the SIP). That really slows the construction and adds a lot of cost. Finally some types of SIP are going to call for hardibacker type screws ... these are made from tool steel for hardness but they rust through the paint on the exterior unless deeply countersunk and sealed with waterproof spackle or stucco.
26 May 2016 12:55 PM
Posted By vh2q on 26 May 2016 10:52 AM
vh2q,
Sorry, not government it is the staff housing for an ultra exclusive resort that caters to the whims of Tom Brady, Michael Jordan, Reese Witherspoon, etc..
there is no structural lumber in the buildings whatsoever, all is built with galvalume steel
Owners chose SIPs for speed of construction , this project took just 90 days to complete, whereas conventional methods would have taken 2-3 years
FYI: deeply countersunk screws in hardi-plank siding pulls through and will not resist the wind forces, blind fastening eliminates the screw exposure to the elements.
23 Sep 2016 06:02 PM
sent last evening from owner
19 Oct 2016 10:25 AM
Reported from owner Hurricane Mathew was category 3 when it hit and was on the right side of the eye wall, only minor damage , this building was mostly 3" thick panels
20 Nov 2016 08:18 PM
These courtesy of TORBEN, who happened to be on the island and recognized from this forum.......
richmUser is Offline
20 Nov 2016 10:27 PM
Nice! Notice how fast the grass grows!
RichM
21 Nov 2016 12:30 PM
showing walkway using 6" floor panels .......... .........
21 Nov 2016 12:33 PM
Open web Joists in insulated crawlspace:
Panels shipped to Caribbean on a flat rack, all are shipped in shrink wrapped bundles, the 46" wide panels can easily fit side by side within the rack, not possible to do in a closed container that is only 7'-7" wide
