Garage Roof/Cold Roof
Last Post 15 Jul 2016 12:46 AM by eweingarden. 13 Replies.
eweingardenUser is Offline
12 Jul 2016 05:59 PM
Does a garage roof using SIPs need to have a cold roof on top of the panels?
12 Jul 2016 06:51 PM
Are they metal skin panels or OSB?
12 Jul 2016 08:26 PM
OSB
13 Jul 2016 03:10 AM
It's an interesting question. Seems OSB really needs the air gap to prevent rot resulting from interior air leaking past joints and condensing under the roof. But if your garage is not conditioned then it's a different scenario. Would it be a detached, unconditioned garage?
13 Jul 2016 08:39 AM
The garage will be attached to the house, but will be a non-heated structure.
13 Jul 2016 10:57 AM
Maybe someone else who has more experience with OSB panels will chime in, but I would think if it is attached to the house then you would want to continue the same venting air gap under the roof that you would use on the rest of the structure.
13 Jul 2016 02:23 PM
Although it's attached to the house, there is a mud room between the house and garage, so it's a separate roof from the house.
13 Jul 2016 11:19 PM
No heat should mean no warm humid air to condense. But I'd tape both sides anyway.
14 Jul 2016 07:46 AM
If insulation is not a concern, why would you use SIPs anyway?
14 Jul 2016 08:25 AM
I'm considering using SIPs for ease and speed of construction. The house will be a timber frame enclosed with SIPs. So if the garage can be put up at the same time as the house SIPs, I'm thinking that my labor costs will be lower in comparison to hiring a framing crew to stick frame the garage. I have to do a cost analysis comparing materials + labor for each method, thus, the need to know if a cold roof is needed for SIPs on a garage.
14 Jul 2016 09:01 AM
Posted By eweingarden on 14 Jul 2016 08:25 AM
OK, I see the logic now, the short answer is no it's not needed,
however, you might want to consider doing anyway if you want to keep the fascia detail the same? or if you think you may want to finish it out at a later date as heated/conditioned space
or consider systems that don't require a cold roof
14 Jul 2016 11:12 AM
What kind of system doesn't require a cold roof?
14 Jul 2016 12:26 PM
Posted By eweingarden on 14 Jul 2016 11:12 AM
metal skinned sips don't allow moisture to pass thru and is a good reason they are used in industrial cold storage, clean room and corrosive applications.
People Online People Online: Visitors Visitors: 257 Members Members: 1 Total Total: 258
