Posted By Innova on 11 Aug 2016 10:49 AM
I suggest that you use tile mastic on the cement fiber board in lieu of thin set for a wall tile installation. The cement fiber board does not absorb moisture like Durock and other common backer boards so you may not get a sufficient bond with the thin set on cement board for a wall tile installation. Thin set is OK for floor tile installations on cement board, but I woulds not use it for a wall tile installation.
Thinset is OK for wall and floor tile , I would never advise mastic on floor,
polymer-modified thinsets are flexible and can be used to adhere wall or floor tiles directly to plywood, durock, hardi-Bd, glazed ceramic tiles , VCT and linoleum
