Plywood and OSB nail Base Panels can be used on existing flat and sloped roofs for added R value upgrades to existing structures. The nail base panels can be attached to the existing sheathing and / or trusses without the need to remove the existing sheathing and exposing the home to the elements as is the case with a traditional re-sheathing project. Nail base insulated panels not only insulate the structure, but provide valuable air sealing of the existing structure which leads to increased energy efficiency, better indoor environmental control and air quality. Architects, Designers and building Owners can specify the thickness and density of EPS insulation needed to achieve and / or exceed the applicable energy codes. Increase the R-value approximately 20% more with Neopor® for the same thickness of panel. Nail base insulated panels can be attached to existing or new concrete decks or directly to the existing roof trusses. Attachment is made with appropriate fasteners without removing existing sheathing, saving additional time and money.
javascript:amaf_insertHTML('
');amaf_toggleInline(5678,24560,0);
');amaf_toggleInline(5679,24560,0);
');amaf_toggleInline(5680,24560,0);
