Titan Wall and Stucco
Last Post 26 Aug 2016 07:45 AM by cmkavala. 3 Replies.
mvzUser is Offline
15 Aug 2016 07:11 PM
Does stucco hold up on Titan Wall? Does it discolor or crack? Do the panels separate? Have been hearing some mixed reviews and would like some more feedback before I make a decision to stucco or not. Thanks
DavidBrownEnterprisesUser is Offline
15 Aug 2016 09:28 PM
Our house is built with Structall steel sips. We had the stucco contractor screw wire lath right into the panel, and then apply his stucco. We have lived in this house for 8 years, and have had no cracks. I am not familiar with the Titan Walls, but would think that a similar application would have the same results.
24 Aug 2016 06:55 PM
No stucco cracks in my steel SIP house 15 years old, paper backed lath, the paper creates a bond break and allows for expansion/contraction in the stucco & lath against the panel wall
Posted By mvz on 15 Aug 2016 07:11 PM
MVZ,
if you apply wire lath or fiberglass lath over the panels you would have a successful stucco job.
if you attempt to direct apply a skim coat over the substrate then any movement in the panel would telegraph thru and crack the finish
People Online People Online: Visitors Visitors: 169 Members Members: 0 Total Total: 169
