Cold Roof with Zip System
Last Post 10 Jan 2017 07:32 AM by EdW. 4 Replies.
EdWUser is Offline
09 Jan 2017 09:08 PM
Anyone have any experience using the Zip System to build the cold roof over SIPs? It's been suggested to me with the advise that roofing paper should not be used on the SIPs. Any feedback is appreciated.
09 Jan 2017 09:14 PM
Posted By EdW on 09 Jan 2017 09:08 PM
No you need a secondary water barrier if the SIPs are OSB skins
EdWUser is Offline
09 Jan 2017 09:27 PM
Thanks Chris. Should the valleys be flashed on the SIPs also?
09 Jan 2017 09:41 PM
Posted By EdW on 09 Jan 2017 09:27 PM
absolutely, metal flashing first then paper over that , this is a minimum code requirement in most areas
EdWUser is Offline
Thank you.
People Online People Online: Visitors Visitors: 138 Members Members: 0 Total Total: 138
