Posted By tonyorlo on 01 Mar 2017 02:35 PM
I came across this earlier.
http://www.thermasteelinc.com/sites/default/files/documents/Foundation%20wall%20section.pdf
Speaking to the sales rep, he said they cover the buried wall with 29g galvined steel sheet, and then they apply a membrane over the sheeting to water proof it.
I have access to a large quantity of aluminum composite panel that I can use in place of the steel. The time savings, and simplicity of install is Very appealing to me. On the other hand I am in my 20s and I don't plan to ever build a house after this one so I want it to last. I know for a fact that concrete will outlast me.
I've been weighing both sides out for awhile and I keep going back to what's proven to work. I'd say your right Jon and go with what works.
the detail looks like a bad idea ,
the grace membrane is applied to a thin 29 ga sheet then covered with wire lath ( the only way to attach that is with screws,now you have penetrated the membrane with thousands of screw holes and then they want you to parge with 3/4" cement)
I would love to see the testing for that ,
just because you access to aluminum panels doesn't mean they can be used for a foundation , they may not be structural or the intended use for below grade.
the foundation of a house is not a good place to experiment
