Posted By greenbuilds on 19 Sep 2017 02:57 AM
Just checking in with an update, things are going well, stuff is getting fabricated...
I was looking at wood-free rot-free subfloors and was wondering if anyone tried USG's cement-based panel? It's designed for steel floor joists (like mine) but targeted towards commercial construction (which is I guess is technically like mine, as well):
https://www.usg.com/content/usgcom/en/products-solutions/products/structural/subfloor/usg-structural-panel-concrete-subfloor.html
5psf is a lot lighter than the 30psf poured concrete floor over fluted steel decking. Says it's rated to over 300 psf (!?) with sufficient joists, but I wonder if it can support vehicles even with that rating.
Seems a shame to build an all-steel house and then build a subfloor out of plywood or OSB.
no it would not support vehicles
each tire print of my 1/2 ton pick up is approx one square foot and a concentrated load of 1,500 lbs
in addition an object in motion imposes a greater(and different dynamics) on a floor than a stationary load
