Canadian Metal SIP?
Last Post 04 Jan 2019 12:26 AM by KevinCasey. 5 Replies.
jcollensUser is Offline
28 Nov 2018 01:02 AM
Trying to locate a Western Canadian supplier of metal SIPs. We are building a residential 3 story structure that requires non combustible walls. Are there any Canadians on here? If not does anyone know another forum where they are more active?
scottishjohnUser is Offline
28 Nov 2018 08:16 AM
non combustible or fire retardant?
big difference
non combustable is ICF or block or brick or stone
28 Nov 2018 04:59 PM
The term I heard was non combustible... will have to dig deeper, It's been hard to get a straight answer from the inspector. All I know at this point is ICF would work to satisfy the requirement.... as well as steel stud or at least 8x8 wood timbers with steel stud infill.
I guess I saw this and assumed with all the flames it would work! https://structuralpanels.ca/product/rockwall-fire-rated-wall-panels/
06 Dec 2018 11:31 PM
Probably not going to find one for residential use , we have shipped to Edmonton before
fallguyUser is Offline
08 Dec 2018 10:12 PM
https://www.gsbp.ca/ is the only Canadian place i have found. Shipping via flat deck is a small coat compared to the whole project IMO
KevinCaseyUser is Offline
There are several OSB SIPs manufacturers that have one and two hour rated assemblies for thier SIPs. I assume that it should be similar to other major cities where the buidings are lesss than 10 foot apart that they require a fire rated wall assembly. There is a manufacturer in Alberta and one in Montana that have the published assemblies in thier code reports.
People Online People Online: Visitors Visitors: 259 Members Members: 0 Total Total: 259
