Steel SIPs - Best Specs For Hurricane protection
Last Post 24 Jul 2020 03:43 AM by YunionBoard. 4 Replies.
Drizzle268User is Offline
26 Feb 2020 10:42 PM
Hey! I am from the Caribbean. I am currently building the slab foundation for the factory I am building. I talked to my business partner and we are going order the SIPs from India, since I import a lot of goods from India, it will be easier. If I were to get them from India, what specifications should I tell the factory for the best Hurricane Protection panels?
Here are my questions:
1- What Density do you recommend for SIPs in Kg for Hurricane protection?
2- What effective width do you recommend for Hurricane protection?
3- What core EPS thickness do you recommend for Hurricane protection?
4- What steel thickness do you recommend for Hurricane protection?
5- Anything else should you add to this that can help?
Thanks! I really appreciate the help guys!!
InnovaUser is Offline
16 Mar 2020 12:50 PM
Steel SIPs are not load bearing and are used as a cladding in most installations. You will still need to frame the structure.
kenmceUser is Offline
23 May 2020 11:47 PM
Dear Drizzle,
I think you may be asking questions that have no real relationship to your problem. The width of the panel, the thickness of it, what kind of fill it has, I do not see how these relate to hurricane strength winds. Those kind of winds will pick up any panel, it doesn't matter what size. The thickness of the outer skin should be enough that it will not be punctured by an object that is flying through the air at the maximum wind speed. In the US we often use a flying 2 x 4 for this test. The Indians will fab up the panel however you say, but they may may not know what exactly you need.
What you really need here is a way to fasten the panels down strongly enough that the wind can not pick them up and send them over to the next island. There are a number of ways, but I have never personally worked with that kind of wind load and am unable to offer more specific advice. If you care to post more, I would be interested to hear how you address this challenge.
CaliforniaUser is Offline
19 Jul 2020 02:56 AM
Wrong. You can have structural, load-bearing steel SIPs. One manufacturer is PermaTherm.
YunionBoardUser is Offline
There are SIPs manufacturer in Chile which is closer to you
Live Green With Yunion<br />
www.yunionboard.com<br />
manufacturer of <A href="http://www.yunionboard.com/product/mgo-board">mgo panels</A>, <A href="http://www.yunionboard.com/product/chloride-free-mgo-board">chloride free mgo board</A>, <A href="http://www.yunionboard.com/product/fiber-cement-panels">fiber cement panels</A>, and <A href="http://www.yunionboard.com/product/calcium-silicate-board">calcium silicate board</A>
People Online People Online: Visitors Visitors: 602 Members Members: 0 Total Total: 602
