SIPs and cold-climate 5-10-20-40-60 rule
Last Post 20 Jan 2021 03:06 AM by cmkavala. 3 Replies.
SIPinterestedUser is Offline
08 Nov 2020 11:53 PM
I have been seeing the advice for "cold-climate builders in North America is the 5- 10-20-40-60 rule developed by the Building Science Corporation" R40 seems high for many SIPs without going much wider. I wonder if the cost is worth it? Any expert commentary? Alternately, does external rockwool over SIP, for additional Rvalue, a hydro-phobic extra thermal break, and rain screen make any sense to make the R40 walls? Cost of rockwool vs wider SIPs? I haven't priced anything out, just musing here...
09 Nov 2020 01:15 AM
What kind of SIPs are you considering? For example, steel skins with polyurethane core or steel skins with Expanded Polystyrene (EPS) or OSB skins with polyurethane core or OSB skins with EPS or fiber cement skins, etc. Since I have used metal SIPs with polyurethane cores in south central, I am just curious what you are considering for your area.
09 Nov 2020 04:20 AM
I haven't previously seriously considered metal skinned, although I see them a lot on this site (just joined). So OSB+EPS or PUR was the original thought. And I'd heard concerns about foam+osb+foam sandwich so thought mineral wool externally.
Rockwool SIPs are not structural
Posted By SIPinterested on 08 Nov 2020 11:53 PM
People Online People Online: Visitors Visitors: 582 Members Members: 0 Total Total: 582
