Are inner walls as important as outer walls?
Last Post 03 Jun 2022 07:08 PM by cmkavala. 7 Replies.
AceMUser is Offline
30 Nov 2021 10:19 PM
We are planning to use SIPs for the outer walls, is it worth using them for the inner walls as well when creating bedrooms/ bathrooms, garage etc;?
newbostonconstUser is Offline
01 Dec 2021 03:05 PM
I am not a sip person but the items I would look into to make your decision because you can go either way....
Are sip walls going to be quieter then stud walls?
Which is going to be cheaper including assembly labor and the cost of the wall?
Which is going to allow for easy duct/electric/plumbing through the walls and the cost effects to the trades?
06 Dec 2021 02:45 PM
For interior walls NO- stud walls are more cost effective and practical .., garage walls yes
06 Dec 2021 06:18 PM
I agree with cmkaval.
CleanBuilding1975User is Offline
16 May 2022 08:43 PM
Inner walls do serve purpose in SIPS as they are using EPS to construct. Therefore any area that is using EPS that can be closed off will hold insulation value including the roof.
Posted By CleanBuilding1975 on 16 May 2022 08:43 PM
an un-needed expense, interior walls are best accomplished with studs for future wiring access, plumbing stack locations and standard door jambs , anyone that says otherwise lacks construction experience and knowledge
People Online People Online: Visitors Visitors: 701 Members Members: 0 Total Total: 701
