strawbale construction forum?
Last Post 17 Oct 2011 10:19 PM by SCIP Panel. 7 Replies.
The PostmanUser is Offline
04 Aug 2008 11:34 PM
Howdy!
Before a serious financial setback, I was a real SIP panel fanatic.  Now it looks like I'm going to have to build a strawbale house.  How about initiating a strawbale forum?  That would really fit in with the GreenBuilding theme, eh?
Are you aware of any real active strawbale forums?  I thought yours was the best as far as SIPs were concerned...
All the best,
Eric Treider
Soldotna, Alaska
JamieUser is Offline
06 Aug 2008 01:49 PM
Hi Eric,
We will monitor the existing forums to see if and when there is enough interest and traffic to warrant a strawbale forum. In the meantime, I suggest posting the topic in the general forum. Thanks for being part of GreenBuildingTalk!
Jamie
Moderator
hydenbrainUser is Offline
27 Feb 2009 02:21 AM
Straw bale building typically consists of stacking rows of bales on a raised footing or foundation, with a moisture barrier between the bales and their supporting platform. Bale walls can be tied together with pins of bamboo, rebar, or wood or with surface wire meshes, and then stuccoes or plastered, either with a cement-based mix, lime-based formulation, or earth/clay render. Bale buildings can have a structural frame of other materials, with bales simply serving as insulation and stucco substrate, which is most often required in northern regions where the potential snow loading can exceed the strength of the bales. Alternatively, the bales may actually provide the structural support for the building.
AntisthenesUser is Offline
16 Mar 2009 05:51 PM
i'd vote for this to happen
poor mans green, breathable earth plastering
mapnerdUser is Offline
18 Apr 2009 11:58 PM
I'd love to see a strawbale forum!!
chrisrichUser is Offline
24 Jun 2009 01:51 PM
I would also love to see a Straw Bale forum. Especially ways to incorporate bamboo in as a substitute for rebar. Bring it!
donsjuandUser is Offline
13 Oct 2011 05:02 AM
I've only found one straw building forum on the net, this could be a nice niche for greenbuildingtalk to tap into I'm actually surprised this website has none. (it just fits)
SCIP PanelUser is Offline
The focus at GBT seems a bit narrow if you are not a SIP or ICF supporter.
I find strawbale homes refreshing, so much more than just another square box.
Plus you have the thermal mass not found with many of the ICFs and SIPs buildings.
People Online People Online: Visitors Visitors: 166 Members Members: 0 Total Total: 166
