ICF footing design idea- need help in making prototype
Last Post 04 Dec 2017 04:31 PM by icfbound. 3 Replies.
Author Messages Not Resolved
bgrunderUser is Offline
22 Oct 2015 02:32 PM
does anyone out there have any suggestions on where to go to get a ICF footing idea made? I have designed a footer that essentially laid into place and most all kinds of ICF straight and or corners can be locked in and stacked upon. So there will be only one pour from footing to the top. What I am looking for is any suggestions on where a person can go to get a prototype made confidentially? I need to finish my testing.
24 Oct 2015 10:19 AM
If you are looking to do this out of moulded EPS, to have a mould made is quite expensive and you would need good drawings. Without know what you are doing it is hard to say.
LieblerUser is Offline
04 Dec 2017 03:48 AM
How are you going to get building code acceptance? Frankly several layers of PWF grade plywood over gravel or lightweight aggregate, in trenches, would make a great footing system under ICF. But getting it accepted by building inspectors would not be easy. IMO footings should be gravel in trenches as used under PWF or Superior Walls. The purpose of a footing is to reduce the pressure on the soil to a level the soil can support. Heavy, brittle concrete is a poor choice of material for a footing. Ordinary gravel or crushed stone is much better and light weight aggregates are even better.
icfboundUser is Offline
This post is over 2 years old... You only dig a trench for footing if you need to go more than 1 foot below soil level for frost line. Otherwise you build a rock pad and put footing on top of it. Way better to put a footing on top of rock pad and back fill than digging a trench. Gets the house above grade and footing can’t fail from uneven settling cause you never know what’s just below the trench. Best to go wider than minimum and spend few more $$$ on concrete if you want a forever footing.
CONservative: The first three letters are all you need to know to fully understand this Republican.
<br /> <br />
Racist: A person who believes their race is superior to another race.
<br /> <br />
Religion: The deception of suckers who fear nonexistence to believe in a nonexistent supreme being and to adhere to false doctrine to control and exploit them.
<br /> <br />
Republican: A greedy, racist, sexist person who skillfully uses deception, hate, fear and religion to control and exploit suckers to gain personal wealth and power to benefit themselves while using government to limit the freedoms, safety and pursuit of happiness of others.
<br /> <br />
Sexist: A person who assaults, discriminates, intimidates or stereotypes the opposite sex.
<br /> <br />
Sucker: A weak minded person who has been brain washed and who usually lacks education and critical thinking skills allowing them to be easily deceived. <a href="https://www.youtube.com/watch?v=vGAqYNFQdZ4">Watch...Don't Be a Sucker!</a>
<br /> <br />
Trumpian: A narcissistic and skilled con artist Republican who is highly attractive to suckers and uses Fascist and Nazi tactics and commits traitorous acts to undermine democracy to gain personal wealth and power.
People Online People Online: Visitors Visitors: 151 Members Members: 0 Total Total: 151
