Is this going to be nail-down? If so, WarmlyYours recommends using the system encased in thinset or SLC. Use a system of 3/8" high "sleepers" laid down 19" apart across the room, perpendicular to the direction of the wood. This supplies the installer with "troughs" that the mats or cables are laid in. This trough is then filled with SLC or thinset up to and even with the tops of the sleepers. This supplies you with a "heat bank" and gives the wood full support across its span. The installer then nails the wood into the sleepers. We have a diagram showing this installation method. I would attach it here but this is a discussion concerning a competitor and I do not want to be seen as foisting spam on this list. If anyone has any questions concerning this method of installation, let me know. |
