Every proper radiant floor, ceiling or wall panel heating system starts with a computer-generated heat load analysis performed by an experienced designer on dedicated software. The heat load will dictated the size of the heat source, e.g. boiler, the PEX tubing size and length, the design water temperature, i.e. the average water temperature needed to satisfy the heat load (coldest few days of the year) and wether or not one needs extruded aluminum emission plates. In the kitchen remodels we do here in Minneapolis, we go around behind professional and novice alike aswering complaints of cold kitchens when an old radiator was taken out for more cabinets and a "radiant floor" installed below the floor without good effect. Often the addition of aluminum plates will satisfy the load, but just as often some for of supplemental heat must be specified as the kitchen floor/radiator has shrunk with the additional cabinets and the floor surface is simply too small. Thus some math is a must. The only thing worse than using an ineffective "short-cut" like stapling up raw PEX below the floor and hoping for the best (extra insulation notwithstanding) is to invest in aluminum emission plates and having a cold room anyway. Why guess? If this is DIY radiant floor, it is misnamed as it is should be; DIY shoot yourself in the foot. GET A HEAT LOAD PEOPLE...before you waste money on PEX, bubble foil, bigger pumps, bigger boilers, more insulation, new thermostats, bigger PEX, etc. etc. etc. |
