I would have to agree with jonr. I think it would work, but movement is your enemy. I saw a poly layer in your stackup, I think I would eliminate it and fasten the foam to the concrete, thinset seems appropriate. I would also do the same at the foam/cement board junction. If you need the vapor barrier I'd tape the foam before you fasten the cement board down, although there is probably one already under the concrete. I'd stagger the seams, no foam board seams on the concrete expansion joints, and offset the cement board seams from both the foam board seams and your tube channels, that way you don't create any hinge points. Last I'd skip any screws, just seems like a bad idea with the tubes under there, and I'd use a modified thinset, that stuff will stick to most things. |
