Posted By Alton on 01/26/2008 11:06 AM
Having access to 39 degree water in the summer as a heat sink should be ideal (very efficient) for cooling in the hot, humid Southeast. Do you have any idea how deep the water should be to be an ideal heat sink for the geothermal system?
I don't think you will find any 39° water anywhere in the hot, humid Southeast. You need cold winters to cool a body of water that cold. Heat pumps are desinged to work with incoming water temps of 90° when in cooling mode. Granted 39° would be better, but you have to work with what you have where you are. Putting an aerator in a pond in the summer will help to keep it cool. Even with incoming temps of 90° a heat pump is more efficient than most other options for cooling.
The data I have seen recommends a minimum of 5' water over your heat exchanger. Here in Utah where we have cold winters, we go with 8' of cover.
Hope this helps.
