Posted By engineer on 09/22/2008 9:26 PM
But if in summer you let the bath water cool to room temp before releasing it onto the loop field you are worse off as that heat is now in the building envelope and needs to be pumped out of the house. Worse yet is the increased latent load from the evaporation off the tub of water while it cools, although that probably displaces some of the sensible load. Even worse is the pushback you'll get from other family members about soap scum lines on the tub walls from the water sitting so long.
Like I said, in the summer you can turn the functionality off by emptying it as fast as possible. Just pull up your 10 cent stopper as soon as the bath is done. Or in the summer make your children take cold baths. I'm sure they'll nominate your environmentalist ways for father of the year on that one.
