Posted By jonr on 25 Jun 2011 10:37 AM
As a side note regarding efficiency, the figures I've seen indicate that one can beat the efficiency of a radiant concrete slab with tile over aluminum panels. You also get faster response time and less overshoot.
Absolutely. It comes down to how much extra you are willing to pay for a certain amount of additional efficiency. I was describing a building where you put the pipes in the concrete, and the only difference is a bit more plastic pipe and a bit more labor effort to put it at 8" OC. To put another subfloor with aluminum on top of the concrete would have been cost prohibitive.
