Posted By Alex_in_FL on 01/23/2010 6:38 AM
If you get oil in your well you are going to have major problems. Cleaning the well will not be fast or easy. But, I can not really see a reasonable pathway for the oil to enter the well. The water is under pressure so any oil leak would likely go to the outside of the unit instead of through an exchanger and into a positive pressure water line.
If cleaning ground water were as simple as Judd makes it appear, I would not be overseeing millions of dollars in groundwater cleanup right.
I think inline loop pumps are generally 1/6 to 1/12 of a horse power and take about 250-ish watts (going off memory).
The coaxial heat exchanger that my system and many others use(s) is just a coil of one copper tube within another. The inner tube contains freon and oil so that, if the copper failed, contaminants would make their way into the water supply via the return line.
I've done some groundwater cleanup myself and you're right, once something gets in the ground its not easy to get out. If the contamination stayed within the well casing/screen then it would be relatively easy. Unfortunately the very flow we depend upon to make these HP systems work is the same flow that contaminates the surrounding aquifer when oil is released to the well.
Thanks for the pump info.
