Posted By leonmeyer on 11/20/2008 1:11 PM
I’m in the process of remodeling my home. I live in Houston Texas and I was curious about re-insulating my attic.
Forgive me if I missed this, but what is your current insulation status and what are you trying to accomplish?
I have owned two older houses in Houston and can offer the following observations.
In a vented attic with insulation in the ceiling, the attic space will be at or above (due to solar) outdoor ambient in the summer and above outdoor ambient in the winter unless the sun is out.
On a hot, summer day, the attic can easily be >120°, and that holds a LOT of moisture. If you have old blown fiberglass insulation and the AC set low, that humidity will find its way into the insulation and at some point condense. You may not have moisture condensing on your drywall ceiling, but your insulation probably looks nasty.
I am guessing you probably have a vented attic and some sort of blown insultation above the ceiling and no vapor barrier. Are you removing the old insulation?
If not, adding a (vented) radiant barrier at the roof framing (preferably leaving an air gap) will probably the most cost effective along with perhaps "touching up" the old insulation where it has been moved/removed.
If you are "starting over", I would go with spray foam (either open or closed) and make a sealed attic as long as your roof is in good repair.
Bruce
