Posted By Kelly Moore on 12/13/2008 9:51 PM
Also if the home is built tight and has super insulation then why would you worry about the thermal mass???
Really, only if you were trying to incorporate some Solar into the mix. Otherwise, I wouldn't expect much of a payback.
Super
Insulate, seal everything well, ventilate properly, and you've done way more than most, and you'll reap the benefits.
