Posted By Bob I on 09 Apr 2013 09:53 AM
Joe Lstiburek, principle at Building Science in Boston recommends putting the poly directly under the cement and above the foam. Given the potential for water saturating the layers under the slab, one wants the foam to be able to dry out by draining into the stone. Putting the VB under the foam prevents this and can result in the foam sitting in a puddle. Sounds like a valid argument to me, so that's the way we do it. Thinking that a layer of poly will, despite joints and potential holes, stop rising water is wishful thinking.
This doesn't make any sense to me. The poly is intended to be a vapor barrier and is not intended to keep water from anything. If you have water rising into your floor assembly, you have a bad design, bad construction, or a disaster. If you have water sinking into your floor assembly, you just have a disaster. The poly goes between the gravel and the foam.
