Maybe consider using Helix Micro Rebar in the slab pour instead of traditional rebar - then that triangular part over the tapered foam thermal break will be sufficiently reinforced and tied into the slab not to break off?
More details for use to code as a replacement:
http://goo.gl/ximfyP
