cmkavala
| 17 Jun 2013 06:17 PM |
Finised Photos............  .................................. |
cmkavala
Finished Photos............  ..................................  |
cmkavala
| 17 Jun 2013 06:21 PM |
Posted By cmkavala on 17 Jun 2013 06:17 PM
Stucco over wire lath, stack stone at portico, stansing seam roof with peel- n-stick underlayment direct to SIPs |
cmkavala
| 17 Jun 2013 06:29 PM |
Underside of Portico with bare white SIPs  Underside of bare white SIPs used for finished soffit with matching fascia trim  |
Lbear
| 17 Jun 2013 09:10 PM |
What type of roof pitch did they use?
Is that overhang around 24" ?
cmkavala
| 18 Jun 2013 06:50 AM |
Posted By Lbear on 17 Jun 2013 09:10 PM
Lbear, the upper main roof is 3/12 all other roofs, tower and portico are 5/12, overhangs are 24" |
Lbear
| 21 Jun 2013 09:30 PM |
Chris, how do they attach gutters to the SIPs since the SIP is open-ended and only has foam at the ends? Where would the gutters attach to and what would the pull-out strength be with a gutter full of water?
cmkavala
| 21 Jun 2013 10:00 PM |
Posted By Lbear on 21 Jun 2013 09:30 PM
The panels come with a matching fascia cap that the gutters attach to with the gutter hanger bracket penetrating to layers of steel, the drip and the fascia, I would guess at about 200 lbs per screw |
cmkavala
| 14 Jul 2013 11:20 AM |
I see several pictures showing slab edges exposed to the exterior. How was this thermal bridge addressed? |
cmkavala
| 14 Jul 2013 11:33 AM |
Posted By jonr on 14 Jul 2013 11:20 AM
jonr, its not addressed at all, there is no reason to be concerned with a thermal bridge that has a 15 degree TD |
Lbear
| 14 Jul 2013 05:29 PM |
I noticed in some pics that where the SIP is screwed down, there is some "oil canning". I know this would be only aesthetic and would be covered by the finishing material but is what I am observing in the pics, correct? The screws seem to distort the metal when they are anchored down, is that true?
cmkavala
| 14 Jul 2013 05:39 PM |
Posted By Lbear on 14 Jul 2013 05:29 PM
Lbear, I am not sure what photo you are referring to?, but it's probably not oil canning, it is probably intentional dimpling, so that the roof/wall cladding will lay flat |
Lbear
| 14 Jul 2013 06:22 PM |
Posted By cmkavala on 14 Jul 2013 05:39 PM
cmkavala
| 14 Jul 2013 06:36 PM |
Posted By Lbear on 14 Jul 2013 06:22 PM
yes dimpled |
Lbear
| 14 Jul 2013 09:45 PM |
Posted By cmkavala on 14 Jul 2013 06:36 PM
yes dimpled
So they purposely drive the screw and create a recessed spot so that the finished material lays flat over the screw head. Do they simply just overdrive the screw? Does the 26 gauge steel dent/dimple easily? |
cmkavala
| 14 Jul 2013 10:09 PM |
Posted By Lbear on 14 Jul 2013 09:45 PM
yes dimpled
yes overdrive, with a little torque |
ricky_005
| 14 Feb 2014 12:16 PM |
Would love to see some close up pics of the metal stud hip and valley beam connections in future projects. |
cmkavala
| 27 Oct 2014 03:59 AM |
Hip with out top plate  |
cmkavala
| 27 Oct 2014 07:43 AM |
ridge beam and hips ......................  .............................................................  |
