Posted By jonr on 04 Jul 2013 10:17 AM
If the bugs get past the siding vents, how do they get from there into the house? Or is this just a "don't give them a place to live" issue?
Down here in Arizona they
don't OSB sheath the walls, it's open framing between the studs. When the put up the Tyvek they rip it and create hundreds, if not thousands of rips in it from nails, staples and if they lean on it too hard from the outside. An insect gets inside the wall through the weep screeds and finds a hole or rip somewhere in the Tyvek, they crawl in, now they have access to the interior wall. They crawl around and will usually come out of an electrical outlet or the baseboard gaps. The other area of entry is that they will climb up into the attic space and then drop down through a light fixture or bathroom vent fan.
They love to live within the wall cavity between the wrap (Tyvek or tar paper) and the exterior finish (usually stucco). At night you can sit there with a black light and literally watch them all start crawling out of the bottom of the weep screeds to go hunting for other insects.
