Posted By jstelmack on 12/11/2009 6:31 PM
Isn't termite infestation a possibility if a sheet of whatever sort of material (Never Rot or Azek) is used similar to a lap siding to bridge the gap from the ICF foam over top of the dimple board and continue below grade?
Good point. When I made my suggestion I didn't have termites in mind since they're not a problem in Idaho. Here again, there is no one best way to deal with the termite issue. A search on termites in this forum should bring up several threads where several options are discussed. Some have even had to cut out a foam strip (don't recall if it's inside or outside, or both) to accommodate a termite inspection strip. If termites are a problem where you're building then you will have to take some sort of preventive action, be it barriers or just poison, or whatever. Another opportunity for ingenuity in coming up with unique solutions or adapting local regular building practices.
All of this discussion points out one of the advantages of using ICF for building - it gives you opportunities to think outside the "cookbook."
