Posted By ICFHybrid on 20 Aug 2012 02:13 PM
Ribbed heads are designed to help that countersinking problem, and the self-drilling points solve the other.
Have you installed cf siding on icf? For one, the siding is on an angle to the foam, so there is a lot of pressure on that top edge. Two, those screws are designed to install a flat piece to a flat piece, so the force will distribute evenly, which won't happen on the siding application. Three, even if the siding doesn't crack while driving these heads flush, the top edge of the siding will likely be over driven into the foam and cause a wavy apperance.
