How to seal around water pipe in ICF basement?
Last Post 06 Feb 2018 12:23 AM by leakyprofessor. 22 Replies.
smartwallUser is Offline
26 Dec 2017 02:58 PM
I've left you in suspense long enough. The most expensive part of the job was shoring the walls of the excavation. OSHA requires any trench more than 5' deep to be shored. With crappy clay, loam soil there was never a question about doing this. You would have to be really stupid to have people working in the trench without it.
NerotinUser is Offline
31 Dec 2017 06:41 PM
U can put a larger pipe in icf wall and then run whatever pipe through it
.. it’s even a code. A pipe should go through a larger pipe. And u can service it all day long any time 5 10 20 Year’s later
.. u less u have a creek of some sort or constant water flowing or for
Ulating. No water will ever penetrate an opening of any kind at mid point. Water looks for easy path and will seep down to the footer where u got drainage and take it away
leakyprofessorUser is Offline
I'm a water proofing company president.
The Leaky Professor at Illiana Basement Waterproofing
When the correct sealing of foundation is applied which is critical as well as drainage dimple membrane such as delta me is applied these areas will or should be addressed. Please be careful as I have encountered several ICF leaders and have had to repair afterwards. It can be done however.
People Online People Online: Visitors Visitors: 255 Members Members: 0 Total Total: 255
