I would think placing horizontal and vertical conduit inside the ICF concrete core section would be way more work than just cutting channels on the interior EPS insulation side.
It might be, but I already have the conduit, and I would rather not cut the EPS if I can avoid it. Besides, with conduit in the walls the wiring is better protected, and I can pull more wire later if I choose to -- without any remodeling or repair work.
The conduit would also hinder the flow of concrete during the pour and possibly create voids.
This won't be an issue if the concrete subcontractor understands the situation and knows how to deal with it. A vibrator and the proper slump can eliminate practically all voids, especially when lifts are only 3-4 feet each.
You still need to have penetrations for exterior hose bibs and electrical outlets.
My hose bibs will not be connected to plumbing inside the house (a zoning requirement based on my desire to have two separate sources of water on the property). Instead the hose bibs will be connected to vertical pipes that T-up from a one-inch water pipe that's buried around the perimeter.
And don’t forget the penetrations required for electrical/water/sewer entry, dryer, HVAC, and stove hood.
I may be old but I'm not so brain-dead that I will forget these things -- not yet anyways!
Electric, gas, water and sewer come in from beneath the slab. The washer and dryer will be located on the covered porch outside the back door so their supplies will come from beneath the porch floor. I will bury 6" galvanized steel ducting beneath the porch floor for the dryer vent.
Yes, there will be penetrations for the stove hood and mini-split, but I think that's all.
