Posted By tmsu on 05/06/2008 10:30 PM
Create air space between the sheet rock and the SIP? Um yeah, no thanks. I appreciate your comments and assume that that this would alleviate the problem. But honestly, this is just silly.....I suppose the poster that mentioned using Hardibacker would create a concrete barrier and thus reduce/eliminate the hollowness but to propose adding even more materials and labor to SIPs goes against using them in the first place.
Exactly! what I have been telling everyone ....... it is the way we install our wiring on our steel sips panels in stead of chases, it makes wiring easier (no cut-in boxes or fishing wires) and the added benefit of an air gap for sound insulation.
This is humorous at best. The
Tin Men are trying to justify adding
materials and labor to their product(which apparently is required, that is, if you want electricity), and trying to justify that as a benefit. Hmmmm.
So, where is that advantage?
