SIPS site supervisor
Last Post 02 Mar 2009 12:32 PM by CTP. 42 Replies.
Page 2 of 3 << < 123 > >>
21 Feb 2009 06:46 AM
Posted By jmagill on 02/21/2009 5:27 AM
Every product has it's good and bad.( and a reason why it is a better choice for a certain job)
jmagill;
you made a true statement.
My background was in the wood industry, it was not any easy transformation to steel.
There are some instances were wood is perfectly acceptable.
I am just of the opinion that if you are building in termite prone areas, it is inteligent to use termite proof products for the structural components of a home.
Insurance does not pay for termite damage.
I still like the warmth and beauty of wood for the interior finishes of a home, but those items don't compromise the structural integrity if infested.
jmagillUser is Offline
21 Feb 2009 06:54 AM
That is the type of post you should be making. The facts!
This constant hard sell and put down of other products only makes you appear dishonest. It is the same as the ICF guys claiming R50 and exagerated thermal mass.
Tell the facts and your products good points and the consumer(me) is far more likely to buy your product.
You have lots of great and important information to offer, it just gets lost when you try to hard sell it.
greentreeUser is Offline
21 Feb 2009 08:04 AM
Posted By cmkavala on 02/21/2009 6:29 AM
Andy;
I myself cannot determine from that photo whether the window was installed incorrectly or  did the the OSB swell to the point of blowing out the frame?
WHAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You know the OSB didnt "blow out" the frame, it was an improperly installed window.
How about these facts:
Steel SIPS will rust out, lose their structural integrity and put your family in danger.  Its possible the rust from your steel SIPS are responsible for autism.  The steel comes from china and supports communism. Salt water will corrode your steel SIPS because the galvanized process is flawed. The chemicals in the steel SIPS are not compatible with most standard building products.
21 Feb 2009 10:10 AM
Posted By greentree on 02/21/2009 8:04 AM
Andy;
I don't know that, and either do you, what I do know is that steel sips are unaffected by water in accelerated aging tests (see attached) while OSB disentegrates before the test is complete.
The test was performed for a competitor, but I have no qualms about posting it
Galvalume steel sips, there is a difference. they will not rust out and in most cases are covered up anyway with a cladding such as roofing/siding.
next to copper , galvalume is the preffered roofing in a salt environment
Attachment: AcceleratedAgingTestreport.pdf
21 Feb 2009 12:14 PM
The test you posted was not done by an independant third party and has been disproven, and its aging cycles arent adequate.
Galvalume panels will rust out beneath your cladding and you won't even know it until it's too late especially in a gulf coast environment, they are impossible to repair without spending copious amounts of money, the rust holes would allow rodents and insects to get into the foam.
If a loose wire or worn sheathing in your service entrance were to come in contact with your steel panels your house would become energized and you or your family would be electrocuted.
Steel sips are likely to fail.
21 Feb 2009 12:31 PM
Posted By greentree on 02/21/2009 12:14 PM
Your "off the cuff" statements are with no factual basis, or history , especially regarding electrical.
Just how does that salt air get  between the bonded skin/foam?
Insects will not infest perfom guard foam.
A grounded steel building is safer than any wood structure, a loose wire touching metal would immediately cause a breaker or fuse to blow.
in a wood structure a short will arc and could catch the wood on fire.
21 Feb 2009 12:35 PM
What do you consider independent third party, it wasn't done by the MFG.
And how was it disproven?
21 Feb 2009 12:58 PM
I heard Galvalume panels will rot out when in contact with fiber cement siding.
21 Feb 2009 01:39 PM
Posted By greentree on 02/21/2009 12:58 PM
Where did you hear that?
21 Feb 2009 02:33 PM
Posted By cmkavala on 02/21/2009 12:31 PM
"Your "off the cuff" statements are with no factual basis"
Oh, now you dont like it when someone else makes blanket statements or statements with no factual basis about your product but those rules dont apply to you? This isnt a forum to make sales, its a forum to share knowledge.
21 Feb 2009 02:41 PM
greentree;
what did I say that was not factual?
Still waiting to hear about the hardie?
If its not for information and sales, then why am I looking at a fischer sips and thermocore ad while I am writing this?
GeorgiaTomUser is Offline
21 Feb 2009 02:51 PM
green tree
are you for real   ?? buying steel supports comunisim?. we still make steel in the us
do you have anything useful to say?
Dick MillsUser is Offline
21 Feb 2009 05:03 PM
GeorgiaTom,
Last year US Steel mills produced about 5 million tons of steel, but the US imported about 38 million tons. On a percentage basis, that means that 88% of the steel used in the US came from a foreign country. That also means that 88% of the earnings from the mill sales of that steel went to foreign countries. So, every time you buy a product that contains steel elements, 88% of the mill price of that steel went to one of those foreign countries, the largest benefactor being China.
21 Feb 2009 07:51 PM
Dick;
it has been my understanding that much of our scrap steel goes to china. do you know if that is true?
21 Feb 2009 08:12 PM
Not sure. I haven't seen any numbers on that. Their smelting operations are much larger, and their labor costs are much lower, and their environmental regulations are virtually non-existent, so I wouldn't be surprised if that were the case. Scrap Iron (steel) and Pig Iron generally trade at about 30% to 40% of steel prices, so it is possible that as much as 10% to 30% of that does funnel back to the US.
21 Feb 2009 08:32 PM
One other thing that is very interesting is that steel prices in mill quantities has been trading in the $130 / metric ton to now $180 / mt range (or $0.06 to 0.082 per pound range) which should bode well for steel sips. From a price/competitive standpoint, steel sips could become highly competitive with OSB sips. Given that a square foot of 26 ga steel weighs 0.75 pounds, the price per square foot of a steel sip (just for the steel) then comes in at less than $0.20. OSB from Canada is trading at about $140 / thousand square feet, or $0.28 per square foot for the OSB on both sides of a panel.
That steel prices have been depressed is also the reason that the US steel industry has shut in more of their capacity for this year, and will probably produce around 4.5 million tons (or less) this year.
lisa6801User is Offline
22 Feb 2009 05:15 PM
Thank you for your response and honesty.  I get tired of sifting out so many "company sales people" from just users at times that I am about ready to go back to timber framing.  As with everyone we are tight with money and am trying to stretch every dollaqr and build well.
My main concern is going with this and trying to get a crew that is knowledgable to put it up.
My second concern is once up using subs that are not familar with this system and mess up the intergrety of it by cutting into the panels for access points like for HAVC from outside to inside or electricl outlets and water.
Third since we want to be GC's for this  and we have plenty of time (retired), I am torn to either commit to a GC for inclosed shell (I may be responsible for window installing) then take over from there.
I am also leaning on geothermal which is another piece of uchatered territory.  Since it may take us another 6-9 months to finish the house onece the shell is up I have a concern again about the exposed panels. yes the roof is up but with weather rain, snow sleet hail do I shoot myself in the foot in the long term or finish the exterior with stucco before the inside is finished?
22 Feb 2009 06:42 PM
Posted By lisa6801 on 02/22/2009 5:15 PM
You should let a GC do the shell, even if its just the box and you do the interior framing. It will take a tremendous load off yourselves and leave you with easier items to accomplish.
Because there is a learning curve, I doubt you would save much by doing the shell yourself
Karen524User is Offline
23 Feb 2009 03:57 PM
Hi Lisa. I have to agree with Chris. You would be better off hiring an experienced SIPS contractor to at least build the shell of your house. Also, that contractor may already work with subcontractors (HVAC, Plumbing, Electrical) who have experience working with the SIPS and can also work for you.
We have built 8 houses here in Florida using the galvalume steel-skinned SIPS and have had nothing but rave reviews from our customers and insurance companies about these houses. Some of the houses we built from start-to-finish, others we were hired to just build the shell, and the owner finished it.
Good luck on your project.
Karen Martin-Brown
Truly Custom, Inc.
877-227-8065
www.trulycustom.com
23 Feb 2009 04:18 PM
Karen;
welcome to the party!
Glad to see you here, Karen is one of the more experienced steel SIP builders in the state
People Online People Online: Visitors Visitors: 247 Members Members: 0 Total Total: 247
