Posted By Haddock@Thermasave on 03/03/2009 1:29 PM
I am sorry but I must have missed your ICC number. I might be looking in the wrong place. We do have the full Florida approval except for Dade County. At the time we did the tests we weren't aware they required a separate test. If you will look at the Florida Code you won't see floors. Where is your company located?
HVHZ applies to both Dade and Broward
We are builders and not required to have an ICC No.,
couldn't figure out the importance on your ICC report as it relies on out dated code information (2001 instead of 2004) and going to require an engineers seal anyway to build in Florida
Was also curious about how you overcome the shingle warranty if attached to a cement board panel.
We are located in Pasco County Florida, State Licensed in FL # CBC036455, Georgia # RLCO000624 and Louisiana #CL33845
